Deletes the specified VPLS or VPWS peer.
| vpls_name | Identifies the VPLS within the switch (character string). |
| vpws_name | Identifies the VPWS within the switch (character string). |
| ipaddress | Specifies the IP address for the peer node that is the endpoint of the VC-LSP. This option applies only to VPLS peers. |
| all | Deletes all VPLS or VPWS peers. This option applies only to VPLS peers. |
N/A.
When the VPLS or VPWS peer is deleted, VPN connectivity to the peer is terminated. The all keyword can be used to delete all peers associated with the specified Layer 2 VPN.
The l2vpn keyword was introduced in ExtremeXOS Release 12.4 and is required when deleting a VPWS peer. For backward compatibility, the l2vpn keyword is optional when deleting a VPLS peer. However, this keyword will be required in a future release, so we recommend that you use this keyword for new configurations and scripts.
The following example removes connectivity to 1.1.1.202 from VPLS1:
configure vpls vpls1 delete peer 1.1.1.202
This command was first available in ExtremeXOS 11.6.
The l2vpn and vpws keywords were first available in ExtremeXOS 12.4.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide
